Generator Info?
Old Aug 1, 2007 | 05:46 PM
Notstock's Avatar
Default Generator Info?
Need help in deciding what generator to buy, mostly wattage size.
I will need to power a small freezer 15 amps
3 other electrical appliances 2 - 10 amp and 1 - 2 amps
The 2 - 10 amp units will be going on and off a lot.
Any other info to help me decide would be great as well.
Old Aug 1, 2007 | 05:51 PM
Kohburn's Avatar
Default RE: Generator Info?
since the generators are rated on their potential output - size it based onthe maximum you see running at once.
so figure figure 45 amps x 120 volts (i assume all the appliances you mentioned are 110-120 volt applications)
= 5400
of course the exact number you said would have been 37 amp = 4440 so 4500..
Old Aug 1, 2007 | 05:53 PM
zzrick's Avatar
I agree with KB, you need to allow for a little overage anyway.
ORIGINAL: Kohburn
= 5400
Old Aug 1, 2007 | 06:08 PM
Notstock's Avatar
Thanks, Guys I was looking at the 5500 models but was not sure.
kb, impressive and here I thought you were just another hack
Old Aug 1, 2007 | 06:10 PM
Kohburn's Avatar
don't confuse macgyver with a hack - he can do nice work when given the right tools
Old Aug 1, 2007 | 06:11 PM
zzrick's Avatar
No...he is a well educated hack
ORIGINAL: Notstock
Old Aug 1, 2007 | 06:31 PM
Notstock's Avatar
Maybe he just search it real quick and wrote a respose
Old Aug 1, 2007 | 06:36 PM
Kohburn's Avatar
haha no - i'm one of those engineer types
Old Aug 1, 2007 | 06:41 PM
Notstock's Avatar
so that means it takes you 6 months of research to decide witch paint to use in your house.
Old Aug 1, 2007 | 06:46 PM
zzrick's Avatar
Everyone else here is a engineer type as well, I just learn from them through osmosis
ORIGINAL: Kohburn
