Bike tie down
Old Mar 14, 2008 | 02:52 PM
firstninjabike's Avatar
Default Bike tie down
Well since this is my first truck and ive never put a bike in the bed of a truck before where do i do a tie down for it. im assuming i put the kick stand down. and should i get the racheting tie downs
Old Mar 14, 2008 | 02:56 PM
Default RE: Bike tie down
no kickstand, yes ratchit tie downs. becareful loading your lowers might hit the ramp.
Old Mar 14, 2008 | 02:57 PM
do not put the kickstand down..... well dirt bikes have different handle bars...but thats where i latch on to to anchor it.... and yes i used those ratchet tie downs... i don trust those ones where you just pull and it tightens up.... i use one on either side of the bike, and usually one across the seat in the back.... id reccomend keeping the bike paralell to the bed rails.... its better, i just leave the tail gate down...
Old Mar 14, 2008 | 03:01 PM
the tie downs will hit the fairing if you connect to the handlebars. what i did was go to the hardware store and take your bolt that holds your bar ends on and get a eye bolt to screw into the end of ur handlebars. just remove the bar ends and screw those in and it's a safe hook up.
Old Mar 14, 2008 | 03:02 PM
but where do i put the tie downs. where do i anchor them
Old Mar 14, 2008 | 03:03 PM
you should have cargo hooks in your bed??
my bed has two tie down points in the front at the bottom of the bed rails.... i actually have 1 in each corner....against the floor of the bed.... my sonoma had tie down points in the front of the bed too......
Old Mar 14, 2008 | 03:04 PM
well i know that one the truck but on the bike where do i hook it up too
Old Mar 14, 2008 | 03:05 PM
here
ORIGINAL: hoedogg
Old Mar 14, 2008 | 03:06 PM
ok i just roll the bike up and just loop it through the eye hooks. i dont have to do anything else?
