Bike tie down
Well since this is my first truck and ive never put a bike in the bed of a truck before where do i do a tie down for it. im assuming i put the kick stand down. and should i get the racheting tie downs
RE: Bike tie down
no kickstand, yes ratchit tie downs. becareful loading your lowers might hit the ramp.
RE: Bike tie down
do not put the kickstand down..... well dirt bikes have different handle bars...but thats where i latch on to to anchor it.... and yes i used those ratchet tie downs... i don trust those ones where you just pull and it tightens up.... i use one on either side of the bike, and usually one across the seat in the back.... id reccomend keeping the bike paralell to the bed rails.... its better, i just leave the tail gate down...
RE: Bike tie down
the tie downs will hit the fairing if you connect to the handlebars. what i did was go to the hardware store and take your bolt that holds your bar ends on and get a eye bolt to screw into the end of ur handlebars. just remove the bar ends and screw those in and it's a safe hook up.
RE: Bike tie down
but where do i put the tie downs. where do i anchor them
RE: Bike tie down
you should have cargo hooks in your bed??
RE: Bike tie down
my bed has two tie down points in the front at the bottom of the bed rails.... i actually have 1 in each corner....against the floor of the bed.... my sonoma had tie down points in the front of the bed too......
RE: Bike tie down
well i know that one the truck but on the bike where do i hook it up too
RE: Bike tie down
here
ORIGINAL: hoedogg the tie downs will hit the fairing if you connect to the handlebars. what i did was go to the hardware store and take your bolt that holds your bar ends on and get a eye bolt to screw into the end of ur handlebars. just remove the bar ends and screw those in and it's a safe hook up. |
RE: Bike tie down
i like HD's idea.....
you could get something like this.... http://www.baxleycompanies.com/Sportchock.html http://img.villagephotos.com/p/2005-...910/img169.jpg |
