Tires
  #41
Old 06-24-2007, 02:11 AM
Default RE: Tires
ORIGINAL: srobak
if you do more tour-type riding and lots of highway and not so much hard-pounding twisties - 220's... if you are a borderline track rider when on the street however, i would say qualifiers... maybe a mix of the 2 - a 220 on the back and a q on th efront. I am actually considering to do this as my front is starting to get there.
btw - the PPs mentioned earlier in the thread are on recall.
sro....not sure if that is what you would want to do. Mixing tires like that.
  #42
Old 06-25-2007, 02:51 AM
srobak's Avatar
Default RE: Tires
I don't know why people always say not to do it... this isn't the first time I have done it, and i have never really had any problems. Right now I have a Metz M1 on the front and the D220 on the back... and I have to say it handles tons better and is far more stable and confident than it was with just the Mets'z... I also used to run Sportmax 2's on the backs with Sportmax 1's on the front back in the day on the 7. I think the *right* combination of tires can yield some pretty satisfactory results... obviously so long as you don't go mixing two extreme tire types... *shrug*
  #43
Old 06-26-2007, 04:06 AM
Default RE: Tires
That is cool sro. Tires as you know have different properties and warm up or wear or grip differently. Of course you know that. I am not a scientist and only a rider with limited funds, so I stick with sets only. I prefer to play with suspension over different brands of tires. No insult to you what so ever sro.
  #44
Old 06-26-2007, 04:31 AM
srobak's Avatar
Default RE: Tires
understood... and I know everyone preaches and likes to practice matched sets. I was thinking about this earlier today some more and another thing that I came up with was since the front and rear are actually doing drastically different jobs with much different geometry and behaviours and factors affecting them - maybe mixing a front that is really good at what a front does with a back that does really good at what a back does isnt such a bad idea
  #45
Old 06-26-2007, 04:58 AM
Default RE: Tires
That takes as much $ and time figuring that out than it does changing fork oil wt and some suspension tweeks. I like both ends to either drift at the same controllable rate or stick at the same controllable rate. Then again everyone has their own style of riding also.
  #46
Old 07-18-2007, 02:51 PM
Donvier's Avatar
Default RE: Tires
Ladies and Gents, this is when you know you need new tires... too bad i didnt see that b4 i drove 60 miles on them... thats luck baby
  #47
Old 07-18-2007, 03:55 PM
srobak's Avatar
Default RE: Tires
No that is when you know you need to move somewhere that has the occassional curve.
Chicagoland is all straight gridded roads, even way out in the suburbs, and mine don't get anywhere near that bad right in the center. You don't have any wear just an inch off the center stripe - that's nuts!
  #48
Old 07-19-2007, 03:58 PM
Donvier's Avatar
Default RE: Tires
I know I feel the same way, the sides are like brand new!
By the way, the manual for my 9 says it comes stock with a 190 on the rear... so NOW im running 10 outa spec
do you think maybe im running over-inflated? i wentwith the manuals air specs but i mean thats some seriouswear.....
  #49
Old 07-20-2007, 03:43 AM
srobak's Avatar
Default RE: Tires
eh... what year is your 9?
  #50
Old 07-20-2007, 04:49 AM
Default RE: Tires
so much for stock pressures too!
olderthandirt
05-03-2009 07:17 PM
Roadrage
Ninja ZX-10R
04-09-2008 07:55 PM
DeFran
15
06-05-2007 12:32 PM
c10
08-02-2005 10:08 PM
Eklipse636
07-27-2005 02:08 AM
Quick Reply: Tires
