Front Wheel Removal
Old 03-02-2007, 07:46 PM
migue_pr's Avatar
Default Front Wheel Removal
I'm trying to figure out how to remove the front wheel on my 02 zx9, I recently hit a pot hole that bent my rim significantly. I've been on various web site but none seem to have specific information on the ZX9. My doubts are: there are 4 front axle pinch bolts (2 on each side) do I need to loossen them on both sides prior to loosening the front axle? Which axle side do I need to loosen first? there are 2 different bolt sizes one seems to be a 19mm and the other 22mm.
Is there a web page that addresses these questions?
By the way I bought the bike a few months ago, and finding accessories has been a nightmare, chroming has been costly and parts are rare, thinking about changing to a HAYA.
Old 03-03-2007, 05:22 AM
jl4049's Avatar
Default RE: Front Wheel Removal
Mines a C1 model and on it remove the pinch bolts from both sides then using an inhex socket and breaker bar on both sides I undo the axle nut from the left fork, with draw the axle through the right fork, you may need to give the end of the axle a gentle tap from the left side to get it started, installation is the reverse, I torque up the nut then lock all four pinchbolts.
advtouring
08-23-2016 10:17 PM
rouzier
Z1000
05-13-2011 05:31 AM
Sid Post
01-27-2009 01:46 PM
rhinografiks
08-15-2006 08:49 PM
SliverR6
06-11-2006 06:47 AM
Quick Reply: Front Wheel Removal
