tune up time
i got my 97 7 apart right now to repaint it, what kind of air filter should i use?? i have a muzzy full system,figured i might as well change it while its all apart, looks origional, and what plugs should i use??? thanks for the help.
I believe that the ngk's are a CR9e, I did not check my manual yet on that. I have the k&n in the 7 right now. If you are familiar with washable filters, do not over oil them after cleaning.
what is the recomended gap on those plugs??? i dont have the manual, also will going from a stock air filter to a k&n, will that change the air/fuel mixture to the point where the bike needs to be re-jetted....i have no idea if the jets are stock or if they have been changed with the pipe, or can i just switch it out and be on my way, im not sure how tempermental these things are.
i have no idea where to even begin when it comes to jetting on these things, used to havean idea when i used to snomobile, but that was 10 years ago, should i contact muzzy and get there specs? i dont even know for sure if it is a full muzzy system, looks like stainless steel all the way back so im guessing it is, im gonna try to contact the guy i bought it from and see what he can tell me, chances are i wont be able to find him, hope im not driving you nuts with all these questions drag but you seem to know your S#$T
Muzzy will have some recommendations on the carb setup. Have your elevation number handy.
I still use the stock needle shape but just shimmed them for my mid rpm and transition power. That was while tracking with the stock exhaust. I still have not installed my full Muzzy yet. (been in the box since 2000 I think, lol). So any numbers I give you will most likely not work for you.
Thanks for the compliment though.
