OIL LEAKAGE
Old May 13, 2007 | 11:34 PM
preemo_21's Avatar
Default OIL LEAKAGE
I'M STARTING UP MY 93 ZX7R LAST WEEK FOR THE FIRST TIME SINCE OCTOBER OF LAST YEAR AND I GOT SMOKE COMMING OUT OF MY EXHAUST, SO I TOOK MY FAIRINGS OFF TO GIVE IT A LOOK AND I SEEN OIL LEAKING FROM THE BOTTOM OF MY EXHUAST..I FOLLOWED THE OIL FROM MY EXHUST UP TO THE MANIFOLD...THE OIL IS GOING IN THE SECOND MANIFOLD PIPE EVERY TIME I START MY BIKE AND I DON'T HAVE A CLUE WHY..CAN SOMEONE HELP ME? THANX
Old May 14, 2007 | 04:15 AM
Default RE: OIL LEAKAGE
Manifold? You talking about the banjo bolts to the heads that are leaking?
Old May 15, 2007 | 04:37 PM
preemo_21's Avatar
I BELIEVE SO..IT'S ONLY LEAKING FROM THE SECOND PIPE(FROM LEFT TO RIGHT) WHEN I START MY BIKE UP AND DON'T KNOW WHY..IT'S WASN'T LEAKING BEFORE I GARAGED IT LAST YEAR.
Old May 15, 2007 | 10:42 PM
You will have two lines on cylinders #2 and #3 on the head. Standard banjo bolts with crush washers. Try snugging the seeping one down to torque and try that. Otherwise just get another crush washer. That is if the line itself is ok.
Old May 27, 2007 | 05:21 PM
preemo_21's Avatar
I WENT TO A BIKE SHOP A COUPLE DAYS AGO AND I TOLD ONE OF THE MECHANICS MY PROBLEM AND HE SAID IT IS MY VALVE COVER GASKET
Old May 27, 2007 | 05:35 PM
Bluebeast's Avatar
that's posible. look to see if it's leaking from the top of the motor if it is then it's the valve cover gasket.
Old May 28, 2007 | 03:19 AM
ORIGINAL: Bluebeast
I could agree with that one also. So exactly where is the trail of oil?
airkorth
750
Jul 11, 2013 06:42 PM
Fever
Aug 6, 2006 02:09 PM
slablocal
Jul 8, 2006 08:21 AM
kawi636
Apr 4, 2006 09:26 PM
