Newbie Maintanance Question - Air Box
Old Mar 8, 2008 | 07:15 PM
Smorphine's Avatar
Default Newbie Maintanance Question - Air Box
1994 ZX7,I need help getting to the air filter and spark plugs.
I have removed the gas tank, looking at the air box now. The boxhas vacuum hoses to it and about 6-7 screws that runthru the middle of it (on top).There seams to be a air filter cap on the side of the air box. Doesn't seem to lead to theremoval of the filter itself. I'm afraid to just lift the box off the carbs.
Would like toremove the air box to get to the spark plugs to replace them too.
Any info will be appreciated.
Thx
Old Mar 8, 2008 | 07:27 PM
Default RE: Newbie Maintanance Question - Air Box
pop the screws on the lid and get er done! Plug removal the airbox does not need to be removed.
Old Mar 8, 2008 | 07:29 PM
stone_sour09's Avatar
well, i have an 01 zx7, but they haven't really changed much on them since then. you should just have to unscrew those on the top that you mentioned. Then, you should be able to open up the air box where the air filter is (obviously). And again, i'm not sure how close mine is to yours, but then at the back of my air box there are 4 more screws next to the carbs that you take out and then you can just slip the rest of the air box off around the carb intakes to get to the spark plugs. The plugs are probably going to be down in like little shafts that you'll be able to get with a rachet and an extension.
Old Mar 8, 2008 | 07:48 PM
Smorphine's Avatar
Thanks fellas. I appreciate the quick responses.
JRock420
Jul 26, 2008 02:28 AM
lightguypro
Ninja 650R
Jun 21, 2008 09:46 PM
djen223
Aug 25, 2006 08:20 PM
flyboy110b
Feb 16, 2006 01:44 AM
a16tony
Jan 21, 2006 06:43 AM
