Fairing repair??
Old Apr 3, 2008 | 08:48 PM
moribound's Avatar
Default Fairing repair??
Hey, I was wondering if any of you have made repairs to your fairings instead of buying brand new ones. Did it work out ok? I was thinking about getting crafty with some fiberglass...I have a lot of cracks on my right fairing, and some heavy damage to the front fairing where the right turn signal is (was) connected.
Old Apr 3, 2008 | 09:28 PM
evil636's Avatar
Knee Dragging Pimp
Default RE: Fairing repair??
ive done it with a plastic welding kit, worked great. never really messed with glass tho.
Old Apr 3, 2008 | 09:39 PM
first off MB that avatar is smoking hot[:-]i have seen people use the fiber glass. but like evil said the plastic welding kit is good and imo probally easier too. unless you know fiber glass well i would try plastic welding. thats just me tho.
Old Apr 4, 2008 | 03:22 PM
moribound's Avatar
Alright, I'll look into the whole plastic welding thing before I do anything.
Old Apr 4, 2008 | 05:48 PM
94Ninja250's Avatar
Can anyone point me in the right direction for buying a plastic welding kit? I have some broken mounting points I'd like to fix.
Thanks
Old Apr 5, 2008 | 06:23 AM
preemo_21's Avatar
i bought bondo fiberglass repair kit from walmart and it works great. no xperience necessary , just read n follow instructions.
Old Apr 7, 2008 | 02:09 AM
bigbrew's Avatar
i had a couple of small cracks im mine when i painted mine this summer....i used a soldering iron to melt the crack back together, used a little two part spot putty to fix any low spots on the outside of the fairing, the bondo with the fiberglass in it on the inside, this stuff is a little messy but will strengthen everything a great deal. its easy to use, get the amount you think you will need out of the can, mix it with the hardener real good, should be like a brown color and get it on the fairing, i just used my fingers to spread it on in tight areas, about a 1/16 of an inch on the inside of your fairing will strengthen it a great deal, this stuff drys pretty quick too, i also used it to fill a hole in one of my fairings, cant even tell it was there any more, use a little acetone to get it off your hands and you will be in business....ill check back to see if you need any more help.
Old Apr 7, 2008 | 07:43 PM
moribound's Avatar
Is there anywhere that sells replacement upper fairings for 1990 ZX-750F Ninjas besides that airtech place?
razor1
Ninja 500R
Jul 3, 2007 03:07 PM
aszrael1266
Dec 2, 2006 06:43 AM
helmethead
Mar 18, 2006 08:51 AM
Musicphreak
Aug 18, 2005 09:14 PM
gustabumski
May 25, 2005 05:24 PM
