Looking for reference for rear fairing repair on '07 Ninja 500
Well to make a long story short my 07 Ninja 500 was rear ended while parked and my upper left/right rear fairings are cracked/scraped in the rear where each piece connects to a 3rd plastic piece above the license plate holder that also was damaged. Overall there is plastic welding that needs to be done along with some painting if possible....the plastic repair is obviously more important. I'm looking for some guidance on how to get the pieces repaired or if someone on here knows of a reputable source for repairs Id ***greatly*** appreciate it. I'm located in Milwaukee, WI. if anyone local sees this and can help out. Links to the damaged pieces:
upper rear left side - 1
upper rear right side - 1
rear piece above license plate holder between fairing sides -1
rear piece adove license plate holder between fairing sides - 2
upper rear left side - 2
upper rear right side - 2
I'd clamp it back together and get a cheapo plastic welding kit from harbour freight or something. then put some body filler over the seams when you're done and sand them smooth.
