Changing tire
Old Jun 12, 2007 | 04:58 AM
AZ_Kid's Avatar
Default Changing tire
I am looking to pull the rear tire. The problem is i don't have a stand. What could i use to keep the bike up w/ out the tire.
Old Jun 12, 2007 | 05:16 AM
Default RE: Changing tire
You could use a steel rod that will go in thru the swingarm pivot and use two jack stands. I use that method when setting up my suspension. Holds the ride up.
edit: Do not use cold rolled steel, it will just bow on ya.
Old Jun 17, 2007 | 08:07 AM
AZ_Kid's Avatar
Thanks Dragone
Old Jun 18, 2007 | 03:23 AM
KEEFFIE's Avatar
I just pick up the back end and stide some jack stands under the spool spots.
Old Jun 18, 2007 | 04:23 PM
BigO's Avatar
That should work as well. as long as you don't have to do to much wrenching on the bike. Makes it a bit unstable
Old Jun 18, 2007 | 07:53 PM
Mott Power's Avatar
i just jack it up and put some blocks of wood underneath, if you have tie-down straps it makes it easier if you can tie the front down to something as well
Old Jun 18, 2007 | 08:14 PM
Notstock's Avatar
Stands I use these and they are great. Easy on the wallet to.
JB1
Apr 27, 2007 04:28 AM
EMS_0525
Dec 20, 2006 08:30 PM
EMS_0525
May 18, 2006 01:59 AM
Marty
Apr 18, 2006 03:03 PM
ntence
Apr 24, 2005 04:42 AM
