Why cant i get into neutral
Old Jul 19, 2007 | 02:48 AM
Kohburn's Avatar
Default RE: Why cant i get into neutral
improvised the stand and got it back into 1st gear by moving the wheel back and forth till it shifted - just pushing on the shift pedal with my hand no forcing it.
i can do 1st and neutral same as normal now. should i be able to get it into 2nd on the stand with the engine off?
Old Jul 19, 2007 | 08:53 AM
Merdox's Avatar
ORIGINAL: murphmaster5
okay dont understand why but unless im all but at a complete stop i cannot put it into neutral can you tell me why when i try to push it lightly at like 15-20 it will just pop into 2nd.
This is an interesting question since mine behaves differently. I have an 05 and I can shift into nuetral fairly easily from first while moving. In fact the other day I was shifting from first to second and I missed putting the bike into neutral, hitting the throttle hard I darn near red lined it by the time I realized what I did. This doesn't happen often but I have noticed if I shift carelessly I run a bigger risk of putting it into nuetral.
Old Jul 20, 2007 | 02:50 AM
GS247's Avatar
Merdox im right there with you. neutral is a piece of cake while rollin. i can hit neutral from 2nd down to first and also from 1st up in to neutral. it happens alot when im not wearing my riding boots. my tennis shoes flex to much and im so when i shift up into 2nd i miss the gear alot. (hope that makes sence)
Old Jul 20, 2007 | 11:03 PM
speedracer138's Avatar
Re-adjust your shift lever down a little and it may not happen anymore. I had the same problem a couple of times until I adjusted the lever.
Old Jul 21, 2007 | 01:50 AM
zzrick's Avatar
ORIGINAL: Kohburn
Still being macgyver I see...lol....
h8hoos
May 5, 2011 03:49 AM
OR-guy
Jun 24, 2009 02:15 PM
tedphips23
Sep 20, 2008 06:28 AM
NicePaint
Joke section!
13
Nov 26, 2007 03:50 PM
drifterman
Sep 27, 2007 01:53 AM
