what maintenance will i need at 7.5k miles
Old Oct 22, 2006 | 07:38 AM
evor1's Avatar
Default what maintenance will i need at 7.5k miles
so i know at 7.5k ill need to change my spark plugs. what else should i get done? ill probly just get it all done at the dealer. i was thinking throttle body sync, coolant flush, spark plugs but what else?
Old Oct 22, 2006 | 07:50 AM
markmeinteil's Avatar
Default RE: what maintenance will i need at 7.5k miles
make sure to lube chassis joints (steering knuckle, swing arm bushings etc), and check your drive chain slack.
Old Oct 22, 2006 | 09:31 AM
HAHAHAHA, keep that moly lube handy. I would check cam and valve clearances at that time. Do a compression check, etc. Yes, abit of overkill it seems.
Old Oct 23, 2006 | 07:19 AM
speedracer138's Avatar
Okay; Here's what you need at 7.5K miles:
Are you ready?
Oil Change, Check, lube and adjust Drive Chain, Clutch & throttle cables, Check tire pressures, fluid levels, Air filter etc. Just normal stuff. Look in your owners manual of the Service Manual offered here.
rkutzner
Dec 24, 2013 05:08 PM
sir.fur
Aug 30, 2008 04:15 PM
Tinman
Nov 8, 2007 03:51 AM
Scrufdog
Ninja 500R
15
Sep 20, 2007 03:09 AM
jayden
Ninja 250R
Sep 25, 2006 02:58 PM
