suggested maintenance at 12,000 miles
Old Aug 19, 2008 | 04:21 PM
sir.fur's Avatar
Default suggested maintenance at 12,000 miles
hey i have a 2000 zx6r and it just rolled over 12,000 miles and i was wondering what i should have done or replaced at this point maintenance
Old Aug 20, 2008 | 08:51 PM
RonInFla's Avatar
well...
Oil & Filter is a given.(every 4,000)
Air Filter replacement (you only get 3 cleanings before the element deteriorates)
Brake Fluid (at least every year, minimum) should be replaced every other oil change
Spark Plugs (the high RPM and constant firing, the electrode burns off) every 12K is good
Drive Chain (By now the rollers are shot and stretched (even for easy riding)
Grease the rear shock linkage (it gets zero attention regularly anyway)
Fork Oil (rule of thumb: every 12K) it breaks down like any other oil does
I'm almost sure you can download and view that kinda stuff on Kawasaki website. there's a "my bike" section that will give you info based on the VIN # (required to access)
Old Aug 21, 2008 | 03:21 AM
Check this out for info. https://www.kawasakiforums.com/forum...ad.php?t=19450
edit: Welcome to KF
Old Aug 21, 2008 | 05:47 AM
sir.fur's Avatar
Originally Posted by RonInFla
well...
hey thanks, ive done most of that stuff just wanted to make sure their wasnt a major thing i was overlooking, chain looked fine but all have someone else look at it. i just got a valve adjustment and the guy their said the screws on the carbs were all the way in, does anyone know why the previous owner would do such a thing? thx
Old Aug 22, 2008 | 12:22 AM
[QUOTE][guy their said the screws on the carbs were all the way in, does anyone know why the previous owner would do such a thing? thx
/QUOTE]
Your manual will explain that in the carburated section.
Old Aug 22, 2008 | 03:56 PM
RonInFla's Avatar
Probably to rich up the mixture. Does it have an aftermarket exhaust?
When you install a jet kit (usually stage 3), the instructions tell you what to do. And sometimes the air screws are closed, dependant on the needle clip position.
Old Aug 23, 2008 | 01:47 AM
exactly Ron, but without that knowledge, it is a crap shoot.
Old Aug 25, 2008 | 04:46 PM
RonInFla's Avatar
Not if it already ran just fine...
If a mechanic said they were closed, did he do anything?
If he adjusted 'em to stock, and there's a problem, guess who's gonna fix it??
If he was just informing you without adjustment, and it runs, **** it. Leave it be...
Old Aug 26, 2008 | 05:37 AM
sir.fur's Avatar
Default info asked for
no the bike doesn't have a jet kit i wish, and yes the mechanic did adjust them but i dont believe to spec the guy i go to races bikes and ive told him im ordering exhaust so idk but i think it feels better. i know this is kinda off topic but whats a good website for basic maintenance parts like spark plug wires and hoses fans chains and such or is the best thing just OEM
Old Aug 30, 2008 | 04:15 PM
williamr's Avatar
Oil and filter change every 12 months is essential irrespective of mileage.
Check the owners guide for the rest, but at eight years and 12,000 miles riding it will do it more good than anything else.
Screws on the carbs only affect the idle and very low throttle. Their effect becomes insignificant as the throttle is opened wider.
Brake fluid should be good for two years unless the bike's kept in a sauna. Yours needs changing, I'm guessing. I'd be tempted to do a full clean and lube job on everything that moves. Check the brake calipers are free on their mounts and the pistons don't stick. Check fork oil and check that the seals are good. Look for any signs of leaking from the rear shock. Check the carb synchronisation, head bearings, swing arm bushes - anything that can deteriorate with time. Lube everything that moves - stand, footpegs, levers, cables, gear shift linkage, etc.
Very low mileage bikes tend to be either over maintained by amateurs who do more harm than good, or they tend to be neglected. I don't like them.
Stock jetting is correct for stock exhaust and air filter. It's only when you start to change these that the jetting needs to be altered to suit, but the jets can get gummed up on little used bikes. Usual sign is a reluctance to rev clean when the bkes off load.
Rob
stellar_d
Mar 3, 2008 02:30 PM
SemperFiTow
Mar 4, 2007 08:29 PM
mmatz
Sep 17, 2006 10:10 AM
dunndilly
Mar 31, 2006 09:36 AM
