are swingarm sliders really necessary?
Old Jun 14, 2007 | 03:15 PM
fastex500's Avatar
Default are swingarm sliders really necessary?
I already have spiked bar ends for sliders, Is getting the fairing and swingarm overkill? Can I just get the swingarm sliders instead of the fairing sliders since I already have the bar ends installed?
Old Jun 14, 2007 | 03:40 PM
mikeyntnc's Avatar
Default RE: are swingarm sliders really necessary?
Overkill ......not sure about that .You plan on using a rear stand ?If so I would recommend the swingarm sliders .I do not trust putting mine up with the non-spools .It's really up to you as to what you want to put on your bike .Personally I put frame and swingarm sliders on mine .Haven;t changed the factory barends though .
Old Jun 14, 2007 | 04:18 PM
+1 on the swing arm sliders like mike said their great for putting the bike on the rear stand. More for the stand than protection from crash damage.
Old Jun 14, 2007 | 07:26 PM
mikedrinfla's Avatar
Ok go lay your bike down and see what happens to your fairings with just the spiked bar ends..... Better safe then sorry...
Old Jun 14, 2007 | 08:49 PM
speedracer138's Avatar
The swingarm sliders serve 2 purposes; as sliders and as spools also for the rear stand. If I had a choice, I would get the Frame sliders first, then bar ends and swingarm sliders last but if you ever dropped or crashed your bike (hopefully never), the sliders will save a lot of damage to your bodywork, tank & frame. You can get a full matching set for under $200 from 58 Cycle or less on ebay individually (May not be matching though).
Old Jun 14, 2007 | 09:11 PM
aszrael1266's Avatar
The Dude
I don't know if im just dumb or what but are spools and swing arm sliders diffrent? I thought swing arm sliders stuck out more then spools. Are they the same or is there a diffrence?
Old Jun 14, 2007 | 09:46 PM
mikeyntnc's Avatar
aszrael , I just put mine on a couple of weeks ago . When I was shopping I didn't really notice any differances ..........but .......that's not to say there isn'ta differance
Old Jun 14, 2007 | 10:11 PM
spools are just to put the bike on the stand. spool sliders are like frame sliders but with a notch like the spools.
Old Jun 15, 2007 | 04:50 AM
If you use a rear stand, get the spools first. This is my first yr in getting frame sliders, so cannot say much on that topic.
Old Jun 15, 2007 | 10:21 PM
shinobi636's Avatar
Get the frame sliders... Mine saved my body work when I got rear ended. I recently got swing arm sliders, and I can see where they could save the aluminum from getting all dented up.
