sprocket trouble
Old Mar 17, 2009 | 12:10 AM
kjfri189@yahoo.com's Avatar
Default sprocket trouble
I'm changing out my sprocket and chain setup but I'm having a hell of time trying to remove the front sprocket, i have it in gear with someone holding the rear brake and still I'm turning the trans i don't think it's reverse thread it's a 98 Zx6r any buddy have any suggestions please
Old Mar 17, 2009 | 02:51 AM
letizia@iastate.edu's Avatar
try calling your local shop
Old Mar 23, 2009 | 02:57 PM
joe sprocket's Avatar
gonna email you some info at kjfri189@yahoo.com.
Old Mar 23, 2009 | 03:01 PM
i was gonna type it out, but screw that lol.
Old Mar 25, 2009 | 12:42 AM
Make sure that the security washer is totally flattened. A small ripple will cause headaches. Then use an impact wrench on the CS nut. I have had to place a board in the rear rim and swingarm to break loose a CS nut before.
Old Mar 25, 2009 | 03:35 AM
zzrick's Avatar
^^+1, thats what I did to mine. Same model as you also, make sure the washer is flattened, and without an impact it is impossible. I used the aluminum breaker bar wrapped in a towel method to keep the wheel from turning. Good luck...
Old Mar 26, 2009 | 06:33 AM
Merdox's Avatar
What everyone said is pretty much right on, if you have access to an impact wrench it will make life alot easier. But you can do it without one, I know because I did you just have to put something in the back tire to keep it from turning.
kjfri189@yahoo.com
Mar 18, 2009 10:27 AM
Finger Mullet
Jan 16, 2008 08:38 PM
kawicat
Apr 18, 2007 07:22 PM
eztalking
Aug 27, 2005 06:13 AM
