sprocket question
Old Nov 17, 2009 | 12:02 AM
tumuchluvun's Avatar
Default sprocket question
looking for more torque in my 07 zx6r and heard that changing out the rear sprocket can help that a great deal. whut is sotck for number of teeth and is this evn true? anything will help. thanks
Old Nov 17, 2009 | 12:11 AM
95451's Avatar
Welcome To Kawasaki Forums.
Turn On Some Tunes And Enjoy The Ride.
They're a lot of Good Members Here and they will do there Best to Help You out with Your Questions. Sometimes It Takes A Little Longer Then Others. So, hang-in there.
Yes Is True. Myself, Rear Sprocket Up It To 47
Old Nov 17, 2009 | 12:56 AM
There are a few riders in KF with that ride. They should be able to help ya on that question. Also the factory manual will list the chain and sizes of the CS and of the rear sprocket. Welcome to KF
Old Nov 17, 2009 | 01:00 AM
The info from the fiche is this
42041 SPROCKET-HUB,43T
42041-0070 (replaces 42041-0017) 1 $63.74
Old Nov 17, 2009 | 03:26 AM
95451, could you feel the difference in 47 and whut size chain did you have to get goin up that high? and did it suck anything from the top end?
Old Nov 17, 2009 | 06:16 AM
95451's Avatar
My Bad,
I Have a ZX7
Stock Front & Rear Was 16/46. I Only Went Up 1
On The Rear. Same Size Chain.
Sorry If I Confused You.
Old Nov 17, 2009 | 10:18 PM
768 Ryda's Avatar
oem sprockets for the 07-08 zx6r is 16t for the front & 43t for the rear, i would go down one tooth on the front & see if you like that, that should give you that added torque your lookin for man, also your bike came factory with 520 sprockets
Old Nov 17, 2009 | 11:19 PM
joe sprocket's Avatar
Most people I know go -1 up front and +2 out back. You keep the same chain length and get a bunch more torque. You're top end will decrease a bit but nothing major. Put a 60 tooth on the rear and you will top out at 90mph lol.
Old Nov 17, 2009 | 11:20 PM
I'm pretty sure that the '07's chain is a .520 so going to a wider chain isn't necessary.
Old Nov 19, 2009 | 07:40 PM
thanks all!
Jun 11, 2007 05:11 AM
ktn
Oct 27, 2006 08:39 PM
Jacks Dad
Aug 23, 2006 04:16 AM
greenmachine
Aug 15, 2006 05:35 PM
