rust on stock header??
Old Mar 12, 2008 | 11:49 PM
intense_05_636's Avatar
Default rust on stock header??
hey guys i was looking at my header since i was about to change it but i noticed that i had rust on it dont know why maybe becuz i have been caught in the rain im not sure...Do you guys have any idea???? check the pics
talked to a guy and he said that it might be that my fuel is messed up to rich or to lean and that it makes the header get real hott...???
[IMG]local://upfiles/6317/47C073EE56FB4E4EAB5A89645752C547.jpg[/IMG]
[IMG]local://upfiles/6317/4631379545E74370AF78E31DEB459876.jpg[/IMG]
Old Mar 12, 2008 | 11:56 PM
OMalley912's Avatar
Default RE: rust on stock header??
Probably just surface rust from the rain.Use a green scotch brite pad. Should do the trick.
Old Mar 15, 2008 | 06:43 AM
evil636's Avatar
Knee Dragging Pimp
im voting on rain too. ive never heard of a lean mixture causing rust, heat causing discoloration but not rust.
Old Mar 15, 2008 | 08:46 AM
speedracer138's Avatar
Sometimes a lean mixture can overheat the header and cause a change in the metal causing it to rust. Once you get it Ceramic coated, you won't have to ever worry aboutrust again.
mataleao
Jul 7, 2024 06:01 PM
a16tony
Dec 12, 2006 03:12 PM
Icantrideabike
Aug 1, 2006 07:35 PM
KORNOLIO
Dec 5, 2005 11:46 PM
pdrury
Oct 19, 2005 06:17 PM
