removing the license plate bracket?
Old Apr 1, 2006 | 09:56 PM
mr2turbo's Avatar
Default removing the license plate bracket?
i've been trying to remove the rear license plate bracket from a 03 zx6rr and i can't figure out how to pull it off, all the bolts that hold it on are screwed in from the inside, and i can't pull out the truck without taking off the fairing, so i assume i have to remove the fairing, but i can't figure out how it comes off. all i've found are 2 screws under the passenger seat and the 2 pins that you push into rubber gromets near the side of the front seat.
do i need to remove the undertail to get the rear fairing off? or am i missing other bolts to pull it off? or is there an easier way to remove that rear bracket?
Old Apr 1, 2006 | 10:02 PM
evil636's Avatar
Knee Dragging Pimp
Default RE: removing the license plate bracket?
theres probley a few screws under the tail section, and some under the rear seat and possibly gromets holding it on towards the front.
Old Apr 1, 2006 | 11:41 PM
lemac's Avatar
deleted sorry thinking of wrong bike
Old Apr 4, 2006 | 08:17 PM
insidewheat's Avatar
to take off the tail fairing you have to take off 6 black plastic screw looking things, sorry dont know what there called
3 on the left, 3 on the right sides of the bike. there on the bottom side of the tail. I popped mine off with a little flat screw driver be very careful not to scratch the paint. On my 2004 636 there was 2 nuts and 2 bolts holding on the lic. bracket and they are under the black trunk under the rear seat
I took fairing off
truck out
unhook brake and blinker lights
remove 2 nuts 2 bolts (Allen key needed)
lic bracket falls off
I hope this helps a bit.
Austin83
Oct 11, 2011 11:08 AM
open air
Aug 20, 2008 07:06 PM
riccun
Nov 25, 2007 06:21 PM
LordVngr
Oct 30, 2006 06:30 PM
uneducatedstudent
Sep 12, 2006 03:36 AM
