PROBLEMS...PLEASE TAKE A LOOK
Old May 21, 2007 | 04:52 AM
Default RE: PROBLEMS...PLEASE TAKE A LOOK
ORIGINAL: speedracer138
You may want to check for wires touching your exhaust also; The exhaust could have melted through the plastic & wiresunder your seat. They may be resting against the pipe, melted & shorted to ground.
Speed, if the complete check was done, I would think that would have been spotted. Hint Hint again!
edit: My spelling sucks
Old May 21, 2007 | 05:26 AM
speedracer138's Avatar
ORIGINAL: Dragone#19
You can never be too certain. I'm sure something is shorted although it is possible the ECU could be bad.You can always get a cheap used one off ebay and try it out. If you get a used ECU, get one off a ZX6RR; Part number 21175-0066. It has a higher redline cutoff and may evenhave more timing advance programmed in.
Old May 21, 2007 | 01:13 PM
mikedrinfla's Avatar
The zx6rr ecu will just replace the zx6r ecu with no problems I might have to try that. Will I have to re do my power comander map? And if so which one do I have the mapped made for zx6r or zx6rr?
Old May 22, 2007 | 02:49 AM
Run the ZX6R MAP. You shouldn't have to remap because it's alreadyloaded in the PC111.
jhoffy22
Jun 6, 2012 12:35 PM
Bluebeast
Jun 2, 2007 06:14 PM
cwgoff
May 31, 2007 08:43 AM
NOLA500Ninja
Feb 18, 2007 04:39 AM
JETHRO980
Feb 15, 2007 10:06 AM
