power commander question
Old Sep 5, 2008 | 06:54 AM
mikes-si's Avatar
ok thanks guys.. how do I go about taking the power commander off.. just unplug it?
Old Sep 5, 2008 | 11:51 AM
mikedrinfla's Avatar
Ya or if you got a lap top you can take it out to the bike from there. Did they give you the usb cord for the PCIII? Plus a 9volt battery and the plug for that as well I think I can't remember. I know it is a 9volt battery. Can not remember about how it connects.
Old Sep 5, 2008 | 05:57 PM
mikes-si's Avatar
no I dont have the cord for it.. what are you talking about a 9v battery? plug it in where?
Old Sep 5, 2008 | 07:10 PM
JokersSmile's Avatar
There's a 9v battery adapter that plugs into the top of it so that you can give power to the PCIII without having the bike on. I'll post a picture when i get home and can take a pic of mine. you can usually pick them up for pretty cheap. on some sites. looks like this.
http://www.motorcycle-superstore.com...ac=2&zmap=9358
The cable is a pretty standard USB cable. I believe it's called a USB A to USB Mini Cable. Cameras, cell phones, and the like use them.
Old Sep 5, 2008 | 09:03 PM
Because with out the 9volt battery and adapter you can not pull the PCIII out of the bike to install the map. You would have to leave it in the bike. Best set is to have a lap top and the USB cable. Good luck bro Hope it works for you.
Old Sep 6, 2008 | 05:14 PM
mikes-si's Avatar
ok thanks guys.. where can i download a map for it?
Old Sep 6, 2008 | 05:30 PM
candylighting's Avatar
powercommander.com
Old Sep 9, 2008 | 01:17 AM
mikes-si's Avatar
ok so I might just take the power commander off completely.. this would put it back to ORIGINAL stock form right? because thats what they say on powercommander.com... If that doesnt fix it I might have to take it too a dealer to get some suggestions, maybe a new clutch or maybe a problem with a worn down fork or star in my shift mechanisms? I'm not totally sure about anything but I can take it to a dealer and find out whats wrong and do it myself
Old Sep 9, 2008 | 05:18 PM
on the power commander site they should have a zero map.... which would be the same thing as taking the power commander off.... and saves you a bit of work.
Old Sep 10, 2008 | 01:44 AM
GS247's Avatar
yes but if there is a problem with the powercomander it self and you do not fully remove it from the bike the problem could still be there. its not that hard to unplug it.
FallFour
May 24, 2011 02:26 AM
Ratkiller
Jan 15, 2007 08:15 PM
Ian636
Oct 2, 2006 08:07 AM
fender780
Sep 7, 2005 06:36 AM
ntence
Apr 16, 2005 03:03 AM
