Yosh RS-5 slip-on PC3 map???
Old Sep 9, 2008 | 09:47 PM
lucas.poznanski's Avatar
Default Yosh RS-5 slip-on PC3 map???
OK, I'm breaking down and getting rid of my 2005 636's stock can. I meant to keep it, but now that I've stripped away all the clutter in the rear (signals, etc.), it's quite the eyesore.
I've pretty much decided on the Yosh RS-5 slip-on, but there's just one problem: the DynoJet website only has a PC3 map for the full system! Any thoughts?? Is it a bad idea to run this slip-on with the stock map? Does anyone have a custom map for the RS-5 slip-on?
Thanks in advance for any input!
Old Sep 9, 2008 | 10:17 PM
Wrong section for that question lucas, try this one.
Old Sep 9, 2008 | 10:35 PM
Hey thanks for the fix Dragone.
Old Sep 10, 2008 | 01:13 AM
GS247's Avatar
e-mail dynajet and they will tell you what map. Thats what i did cause they dont have a map for my set up
Old Sep 10, 2008 | 03:01 AM
Great suggestion - I've emailed them - hopefully they'll have something to suggest. Failing that, what do you guys think about using the full system map they have? Is this a better/worse idea than using the stock map?
Old Sep 10, 2008 | 02:02 PM
GS247's Avatar
it would probably work. you might run a little fat due to your bike not flowing as much as the full system. They should e-mail you back with in a day though.
I have a Boz Bros slip on and they to me to use a map for a someone elses pipe. it works pritty well together. just on HARD decel i get a little pop which is kind of cool.
speedracer138
May 28, 2008 12:42 PM
kory636
Apr 15, 2008 01:31 PM
evor1
Mar 12, 2006 08:22 PM
evor1
Feb 22, 2006 08:49 PM
xmxracer
Nov 19, 2005 04:31 PM
