Yosh RS-5 slip-on PC3 map???
OK, I'm breaking down and getting rid of my 2005 636's stock can. I meant to keep it, but now that I've stripped away all the clutter in the rear (signals, etc.), it's quite the eyesore.
I've pretty much decided on the Yosh RS-5 slip-on, but there's just one problem: the DynoJet website only has a PC3 map for the full system! Any thoughts?? Is it a bad idea to run this slip-on with the stock map? Does anyone have a custom map for the RS-5 slip-on?
Thanks in advance for any input!
Great suggestion - I've emailed them - hopefully they'll have something to suggest. Failing that, what do you guys think about using the full system map they have? Is this a better/worse idea than using the stock map?
it would probably work. you might run a little fat due to your bike not flowing as much as the full system. They should e-mail you back with in a day though.
I have a Boz Bros slip on and they to me to use a map for a someone elses pipe. it works pritty well together. just on HARD decel i get a little pop which is kind of cool.
speedracer138
May 28, 2008 12:42 PM
