OIL SCREW SUPER TIGHT!!!
Old May 2, 2007 | 06:54 PM
SAMCAR305's Avatar
Default OIL SCREW SUPER TIGHT!!!
Hey guys, Back with another question for you pros!! I was planning to do my oil change this morning when I start having complications loosening the bottom screw that drains the oil... pretty much, ITS SUPER TIGHT!!!! I cant get it loose! I am turning it counter clockwise with the correct socket, the freaking screw wont move!! I am using all my strength and doubt that it should be this hard to loosen this sucker up...The last oil change was done by the stealership, so I dont know what went wrong!!! Any hints on how to loosen this screw please? HELP!!!
Old May 2, 2007 | 07:06 PM
speedracer138's Avatar
Default RE: OIL SCREW SUPER TIGHT!!!
Make sure you use a 6 point 1/2 " drive socket and a ratchet or breaker bar so you have some leverage. It SHOULD not be that tight. Just make sure you are turning it the correct way, becausethe drain boltupside down. If you are on the RH side of the bike, you should be pulling the wrench from front to back. On the LH side (kickstand side) back to front. (Just making sure). If it's still very tight, take it back to the dealer; maybe they cross threaded it but if they did, it will usually leak. You can tap the bottom (head) of the drain plug with a hammer also and then try loosening it.
Old May 2, 2007 | 08:17 PM
hicktown's Avatar
use a breaker bar man or an impact. ppl that tighten things like that **** me off.
Old May 2, 2007 | 08:40 PM
markmeinteil's Avatar
If you can't get it, take it to the dealer. You don't wanna strip the threads in the crank case.
Old May 2, 2007 | 10:43 PM
ORIGINAL: markmeinteil
Yeah, take it back to them since they are the ones who tightened it. If it's cross threaded, they shouldfix it. If you take it off and it's messed up, they will say ou did it. So take it to them.
Old May 3, 2007 | 01:28 AM
SAMCAR305's Avatar
Yeah, the stealership knows how to **** everyone off!!!! the oil filter is extra tight too, these guys are idiots!!!! Thanks for the info. guys, it really helps!
Old May 3, 2007 | 11:17 AM
hmm, as said above use a 6 point socket if it is that tight. and as said, if that does not work send it back.
Old May 3, 2007 | 03:11 PM
jds636's Avatar
i love changing the oil in the bike...i have still yet to buy a filter wrench, so I always have to drive a screwdriver threw the filter
Old May 3, 2007 | 05:39 PM
ORIGINAL: jds636
That way you get to drain all the oil from the filter too before trashing it. I always poke a hole in the filter to drain all the oil too.
Old May 3, 2007 | 08:40 PM
hicktown's Avatar
ya i forgot to say just have the dealer do it and tell them you aint paying for it,.
Highbeam
Jul 6, 2015 10:42 PM
djchan
Oct 17, 2012 01:50 PM
cegusman
Oct 6, 2012 05:38 AM
WHIP-N-DIP
Jul 2, 2012 05:32 PM
T_i_G_e_R
Mar 30, 2011 08:31 PM
