Oil Leak please help
Old Mar 27, 2012 | 05:37 PM
Demonrider's Avatar
Default Oil Leak please help
I have a zx600D. My bike was sitting all winter getting a little work here and there done but once i fired it up last week and let it run it ran great. After about 5 minutes of running i reved the engine a little bit and suddenly oil started spewing all over the ground dripping down the left side, Any ideas? Thank you
Old Mar 27, 2012 | 06:09 PM
jeffzx9's Avatar
I would guess that a gasket let go. I have my su****ions on where, but need more specific info than "all over the ground" and "down the left side."
Old Mar 27, 2012 | 06:10 PM
jeffzx9's Avatar
Gadz, is "su$pici0n" a bad word????
Old Mar 27, 2012 | 07:26 PM
Demonrider's Avatar
it seems to be coming from directly underneath the center of the bike, down the left side over the water pump and onto the kickstand, i havent cleaned the area out yet to check for certain but im pretty sure its almost the center of the bike under the air box
Old Mar 27, 2012 | 07:46 PM
jeffzx9's Avatar
I'd probably check for the oil line tube (as on the other oil leak thread you posted to, with Calamari Chris and Prom photos.) If not an oil tube, clean the area and check gasket(s). I'm guessing there is a tube that "blew off" under rev-pressure. Shouldn't be anything too serious. Post up a pic or three if you're stumped and/or need more help. We'll track it down for you.
Edit: Any "repairs" we should be aware of? Sometimes guys leave out details that make a difference. "Oh yeah, I forgot to tell you....."
Old Mar 27, 2012 | 09:17 PM
yes, check the external oil cooler, the lines, the supply line to the head. Steel lines, banjo bolts, with rubber mid lines.
Jeff- what thread link were you referring to on the CC and prom photo's?
Old Mar 27, 2012 | 10:07 PM
Demonrider's Avatar
i did a little digging and found out that my air filter box is filling up with oil...it seems to be backing up from the engine itself...
Old Mar 27, 2012 | 10:33 PM
dump the oil, oil filter and check the oil relief valve per your manual. The valve could be sticking.
Old Mar 27, 2012 | 10:40 PM
Demonrider's Avatar
hmm ok my one friend said that the piston ring might be shot to but the weird thing is that i just had it running before this happened, its a 1991 kawasaki ninja zx600-D2 any idea where that valve might be?
mikey113
Oct 12, 2024 02:54 AM
Green hornet
Sep 16, 2011 02:10 AM
dmojave250
Jan 29, 2009 02:18 PM
WestOzKLX
Apr 21, 2008 07:23 PM
FiveLiterRiceEater
Jun 26, 2007 01:48 AM
