no oil pressure
i have 02 zx6r and have replaced the head timing chain. after doind so the bike ran great for about a day then i started losing oil pressure. when i took the oil pan off the pickup was clogged with a peice of a rag that i must have dropped in the oil pan{i know i'm a dumb as* but that is beside the point} after i cleaned out the pick and started the bike back i now have no oil pressure at all
help!!'
help!!'
lol, I understand. Then check out your manual, it may be best understood then..
in the front of the engine there is an oil pressure sensor take that off and you should be able to do it from there on zx6r it work hopes that helps, yeah wheir suppose to be helping each other on this site not making dumb comments
help!!'
help!!'
Sometimes it takes a while to build up oil pressure unless you toasted your oil pump. try loosening the oil filter just a little (don't remove it) and cranking the engine until oil flows, they tighten it an run it. Make sure the oil pick-up tube isn't clogged.
Jutboy
Apr 21, 2006 06:05 PM
