How to attatch rear brake light switch to Woodcraft rear set?
Old 06-25-2008, 11:28 PM
kronus's Avatar
Default How to attatch rear brake light switch to Woodcraft rear set?
I recently replaced my factory rear sets with a set from Woodcraft because mine were thrashed, and I found a set on ebay for cheap. However, this particular set didn't come with a bracket/mount for the stock brake light switch. I didn't think much of it, but I'm getting my bike inspected soon, and I need that switch to work, even if only temporarily.
How have you guys attached your switch to your after market rear sets? I'm thinking I'll just zip-tie it to the bracket just for the inspection. But I would like a more permanent and reliable set up. Any ideas are welcome!
Old 06-26-2008, 12:03 AM
jeffzx9's Avatar
Default RE: How to attatch rear brake light switch to Woodcraft rear set?
If you're handy with making small parts; i.e. brackets, etc., go to your local ACE or hardware store and check out the hobby stock metal. It's usually in the Hillman fastener aisle. Find what you need to make a bracket and have at it. If you need to make an extension for the switch activator "shaft," try using a piece of square stock and drilling a hole in either end for the cotter pin. It worked for me when I put some Harris rearsets on my old ZX9. Works as good or better than OEM. While you're in that aisle, get the nuts and bolts (stainless preferred) to tighten the parts together as needed. Good luck.
Old 06-26-2008, 01:01 AM
speedracer138's Avatar
Did you get the rearsets from me? Woodcraft sells a hydraulic brake light switch that is activated by the brake pressure for $20 I think or you can fabricate a bracket for the stock one as mentioned above. You can use zip-ties if you get desperate or for temporary use.
Old 06-26-2008, 03:15 AM
kronus's Avatar
Jeff: Thanks for the idea. I'll stop by our local hardware store tomorrow and see what I can 'create.'
Speed: I'm not sure. I actually bought the right side off of ebay thinking it was both, but obviously I had to find the left side from somewhere else, so I ordered straight from Woodcraft. I didn't see that hydraulic switch on their website, but I'll take another look and see what they've got.
Old 06-26-2008, 03:21 AM
kronus's Avatar
Oooh I think I found what you're talking about, Speed:
http://www.woodcraft-cfm.com/Scripts...dproduct=17452
Geeze, I wish I would've seen that when I ordered my other stuff.
Old 06-26-2008, 07:01 PM
evil636's Avatar
Knee Dragging Pimp
I have a hydro switch if your interested, i dont run the light off the rear. front only.
Old 06-26-2008, 09:59 PM
kronus's Avatar
A Hydro switch? Sorry I'm still a newb, but could you explain how this works? Thanks.
Old 06-27-2008, 01:27 AM
evil636's Avatar
Knee Dragging Pimp
when you step on the rear brake, the pressure is what activates the light. basically, its a banjo bolt for the rear with 2 wires coming off of it.
kennysupermoto
05-25-2014 07:01 PM
dan888
03-09-2012 02:57 AM
Ratkiller
08-11-2008 08:06 PM
speedracer138
03-11-2008 10:43 PM
speedracer138
03-11-2008 04:48 AM
Quick Reply: How to attatch rear brake light switch to Woodcraft rear set?
