"Help! My Bike Won't Start!"
Old Aug 10, 2008 | 10:05 PM
2low4u's Avatar
Default "Help! My Bike Won't Start!"
Ok, my dad ran my 06, 636 out of gas. Now that it has a full tank it still says its out of gas and will not start. From what im told the bike does not have a reserve so I am lost as to why it is doing this. If someone could please help me I would appreciate it. Im new to the bike community so all advice would be greatly appreciated.
Old Aug 11, 2008 | 03:18 AM
zzrick's Avatar
How long did you crank it? It may need to get more gas through the lines.
Old Aug 11, 2008 | 11:22 AM
2low4u's Avatar
Man, I cranked it for at least two minutes. Not straight mind you but off and on for two minutes. I was told these bikes dont have reserves, but I dont know if that is true. Anyway, she still wont start
Old Aug 11, 2008 | 02:26 PM
KawiZX6R2006's Avatar
Try cycling the fuel pump on and off a few times. Turn the key all the way on (should hear fuel pump), then turn the key back off, then repeat a few times. Try starting it after about 3 cycles.
Old Aug 11, 2008 | 05:07 PM
evil636's Avatar
Knee Dragging Pimp
/\ do that a few times and it may take a while depending on how much air you need tyo purge out from the system.
Old Aug 11, 2008 | 07:00 PM
sup_uni's Avatar
+1 just keep it going, it will start eventually. check your kill switch
Old Aug 12, 2008 | 02:14 AM
zzrick's Avatar
Dude I did that when I first got the bike, sooo embarassing! :-)
Old Aug 12, 2008 | 03:39 AM
Merdox's Avatar
You are right these bikes do not have a reserve, instead we have the fuel light. When that light comes on there is about one gallon left in the tank or about 40 miles roughly if your bike is stock.
Old Aug 12, 2008 | 09:08 PM
sup_uni's Avatar
hey rick, you dont know how many people i have hellped over the phone when i was mechanicing that that was the problem, it actuall got to the point where first thing i would ask,
1. kill switch
2. kickstand/gear
3. gas
ok now we can start to diagnose
Old Aug 12, 2008 | 09:13 PM
speedracer138's Avatar
Spray some starting fluid into the Ram-Air inlet while you crank it. It should fire right up.
