help asap
Old Apr 11, 2007 | 10:44 PM
20000greenzx6r's Avatar
Default help asap
i got a 00 zx6r and was riding the other day and hit the gear lever and without the clutch pulled in at all i could switch gears anyone know why this is ?[/align]
Old Apr 11, 2007 | 11:04 PM
SERGE's Avatar
Default RE: help asap
Don't worry. Most of us do it. There is a point where the gears are "syncronized" an you can "slip" from one to the next without the clutch. It is easier in bikes than in cars and I woul not recommended it in low gears (1 and 2).
Old Apr 11, 2007 | 11:39 PM
now what if the bike is just idling and i hit it into first it still does it without clutch
Old Apr 12, 2007 | 01:42 AM
05ZX6R's Avatar
Motorcycles have a "constant mesh" style clutch that is constantly gripping and slipping enough so that the clutch is not needed for upshifts, completely different from cars, there is no special sync'd spot. Downshifting without the clutch is not great for it but can be done, just not recommended. If you are in neutral, at idle and hit the shifter into 1st the bike will barely move forward before stalling, you probably won't even lose balance. Just be careful not to hit it when on the bike.
When racing, I never use the clutch to upshift. I keep my foot under the shifter with just a little pressure. When I want to shift, I blip the throttle a little and kick it up a gear. Goes smooth as butta!
Old Apr 12, 2007 | 01:50 AM
hicktown's Avatar
ORIGINAL: 20000greenzx6r
it might pump forward but itll die for sure
Old Apr 12, 2007 | 09:03 AM
speedracer138's Avatar
Almost all motorcycle racers upshift without the clutch and there are quickshift devices that you can buy that allow you to upshift even without letting off the gas. These devices cut ignition for a millisecond to take the load off the transmission gears and allow them to slide to the next cog. If you practice and get really good, you can do it almost as fast/ quickly.
Old Apr 12, 2007 | 09:08 AM
lemac's Avatar
I hit in in gear once when I started rolling backwards thinking it was the brake. Well it just died with a weak lurch.
Old Apr 12, 2007 | 09:41 PM
Rains's Avatar
hahahah so that's what is meant by a 05 636 Slipper-Clutch! No clutch needed to upshift! hahahaha!
joshmoe
May 13, 2014 02:24 AM
reverend d
Jan 9, 2007 06:54 PM
2001ninjaZX6R
Aug 13, 2006 12:06 AM
jayden
Ninja 250R
May 1, 2006 04:24 PM
clipse2k
Aug 18, 2005 01:31 AM
