headlight adjustment help!
Old Jun 24, 2007 | 03:43 AM
kozumasbullitt's Avatar
Default headlight adjustment help!
i did the dual headlight mod on my 06 636 and i am having trouble with the brake side headlight...... i got both beams to be on the same level by using the upper gold bolt but the width of the brake side is much smaller that the clutch side... what do i do for this? thanks in advanced.
Old Jun 24, 2007 | 08:27 AM
kazerotor's Avatar
Default RE: headlight adjustment help!
did you remove the clutch side little cover that goes in front of the bulb?
Old Jun 24, 2007 | 09:37 AM
yes i did.
Old Jun 25, 2007 | 04:19 AM
bump
Old Jun 25, 2007 | 03:21 PM
Ratkiller's Avatar
I don't think there is anything you can do. If you look closely the mirror protion of the two lights are different.
Old Jun 26, 2007 | 08:35 PM
speedracer138's Avatar
You just adjust it to the same level. I should be one flat beam across with hardly any space between them. I usually adjust the upper outer screws.
Old Jun 28, 2007 | 02:12 AM
PANGUI's Avatar
it might be a mix up in your wiring i just did mine and had one of the wires hooked up wrong having one with the high beam on and when i switched it the other side looked funny took it apart and it was one wire off
Old Jun 28, 2007 | 06:29 AM
well i think they are right, just one side has a larger beam( wider). are you beams equal width? i cant barely tell because i am blinded from looking.
Old Jul 1, 2007 | 11:37 PM
PANGUI's Avatar
you have to use sun glasses or you'll be blind for a while
grouch
Jul 23, 2009 01:51 AM
grouch
Jul 21, 2009 07:04 PM
ezrollin
Ninja ZX-7R
Jan 29, 2008 08:21 AM
yas001
Ninja 250R
Oct 30, 2007 06:54 PM
