headlight adjustment help!
i did the dual headlight mod on my 06 636 and i am having trouble with the brake side headlight...... i got both beams to be on the same level by using the upper gold bolt but the width of the brake side is much smaller that the clutch side... what do i do for this? thanks in advanced.
RE: headlight adjustment help!
did you remove the clutch side little cover that goes in front of the bulb?
yes i did.
bump
I don't think there is anything you can do. If you look closely the mirror protion of the two lights are different.
You just adjust it to the same level. I should be one flat beam across with hardly any space between them. I usually adjust the upper outer screws.
it might be a mix up in your wiring i just did mine and had one of the wires hooked up wrong having one with the high beam on and when i switched it the other side looked funny took it apart and it was one wire off
well i think they are right, just one side has a larger beam( wider). are you beams equal width? i cant barely tell because i am blinded from looking.
you have to use sun glasses or you'll be blind for a while
