Got my dynojet shifter today
Old Jan 25, 2008 | 09:38 PM
TORA's Avatar
Default Got my dynojet shifter today
Got my power commander shifter today and the instructions are lame for my 05 636, does it actually push when I push or does it only kill the fueling for a quick second. I was under the impression that it pushes the shifter like an air shifter I havent put it on yet and do I have to set the kill time before it will work correctly, or will it work fine once it is plugged in without having to get out the laptop or going to the dyno guy first?
Old Jan 25, 2008 | 11:03 PM
kory636's Avatar
Default RE: Got my dynojet shifter today
Havent dealt with one of those DJ ones before. I havent heard too many good things about them, so let me know how it goes for you. Hope everything turns out ok for you TORA and good luck installing it.. Keep us posted
Old Jan 26, 2008 | 03:22 AM
sup_uni's Avatar
do you have a pic by any chance or the site you got it from, good luck
Old Jan 26, 2008 | 03:58 AM
speedracer138's Avatar
It works by cutting out the ignition for a millisecond to unload the transmission so you can upshift. I does not assist or make the shift like an airshifter.
Old Jan 26, 2008 | 05:45 PM
TORA's Avatar
Thanks I will put it on as soon as I get time, I have to put on A new stock swingarm new brake caliper new wave rotor from galfer and rebuild my shock before I really get time for this I am also getting a factory pro shift kit to aid the shifting as well but thanks guys for responding. I will take it to my dyno guy after I get all of this stuff done and see how much faster my bike is between K@N and BMC and yoshi on a 05 636 with no smog connected and a quick shift DJ and factory pro shift kit,hopefully it all makes a big diff
Old Jan 26, 2008 | 09:44 PM
The quick shift will not help out on the dyno TORA
Old Feb 1, 2008 | 10:20 PM
kory636's Avatar
you really want to improve some time send that dynojet quick shifter back and get you an air shifter from Schnitzracing.Com, or MPS racing. Do it all with the push of a button, save you a couple 10ths of a second.
Old Feb 12, 2008 | 10:49 PM
TORA's Avatar
I think I need a ignition module to run this stupid shifter! Anyone know? Anyone run this?
Old Feb 12, 2008 | 11:18 PM
I don't think you need an ignition module but am not 100% certain. However, The ignition module will give you more power by advancing the timing.
Old Feb 13, 2008 | 11:07 PM
Droz32's Avatar
Yes you need the ignition module, some bikes need it some dont.
http://www.hardracing.com/IgnitionModule.htm
warsanrotts
Sep 16, 2007 04:25 AM
suprakawigrl
May 21, 2007 07:52 PM
CowgirlCandy33
Apr 25, 2007 08:42 PM
Nobrakes
Nov 6, 2006 05:11 AM
frrogger1
Aug 1, 2006 07:54 PM
