Fuel in my Oil...?
Old Jun 18, 2006 | 08:29 AM
Default RE: Fuel in my Oil...?
Just the SB lines, the penske and the traxxion may go in this week. No engine mods.
Old Oct 29, 2006 | 03:52 AM
t56emac's Avatar
I had fuel in my oil once on my Harley, and my rings were bad.
Old Oct 30, 2006 | 07:16 AM
speedracer138's Avatar
Fuel in Oil: On fuel injected bikes it is probably a leaking injector. On carbureted it's a float seat stuck open. Also On Carb'd bikes the fuel petcock/ selector diaphragm can leak and fuel will get sucked in through the vacuum hose that goes from the tank valve to the carb/ intake manifold boot. If you have this problem, diagnose & fix it ASAP because the fuel can cause a Hydraulic lock in the cylinders and you can break a piston or connecting rod or worse.
Old Oct 31, 2006 | 04:49 AM
Agreed, I changed the oil/filter out shortly after I noticed my issue. To double check. Mine seemed to have cleaned up.
Warren3000
Oct 27, 2012 11:42 PM
rajdeep
Oct 18, 2007 04:10 PM
JSTER
Sep 16, 2007 02:59 AM
kawi636
Apr 4, 2006 09:26 PM
