Ca fuel tank replace with non ca fuel tank?
Old Oct 27, 2012 | 10:30 PM
Warren3000's Avatar
Default Ca fuel tank replace with non ca fuel tank?
I need to replace my fuel tank on my 09 sf ca model (the metal fuel vent line inside the tank has somehow devoloped a tiny hole and fuel leaks out the vent tube under the bike when the tank is more than half full) My question is can i use a tank from a non-ca model if my bike is desmogged (since the ca model tank only has 1 or 2 extra vent tubes coming from the bottom for smog stuff and i wont be using them anymore) also is it easy to transfer the gas cap over?
Old Oct 27, 2012 | 11:42 PM
Brewster's Avatar
If the leaking part of the tank is part of the emission control functions, you may be able to get a new tank under warranty. Check with a dealer.
edit: Calif. regulations covering emission control devices;
http://weblinks.westlaw.com/result/d...0&sr=TC&vr=2.0
Ride on
Brewster
Bettle Bailey
Feb 18, 2013 01:49 PM
scat
Jun 12, 2007 03:11 PM
600nonR
May 24, 2006 06:36 PM
600nonR
May 19, 2006 10:15 PM
motoguy128
Mar 19, 2006 07:24 PM
