Fuel in my Oil...?
Fuel in Oil: On fuel injected bikes it is probably a leaking injector. On carbureted it's a float seat stuck open. Also On Carb'd bikes the fuel petcock/ selector diaphragm can leak and fuel will get sucked in through the vacuum hose that goes from the tank valve to the carb/ intake manifold boot. If you have this problem, diagnose & fix it ASAP because the fuel can cause a Hydraulic lock in the cylinders and you can break a piston or connecting rod or worse.
grant1
Mar 27, 2009 03:08 PM
