FI Light fix needs to be fixed
I installed two brothers pipes on my bike and installed the fi light fix piece of metal.This was three weeks ago and everything worked dandy until today.I noticed my FI light on so I took off the seat and found that the screw had vibrated out and the piece of metal was wedged in the compartment.I reinstalled the fi light fix again the same way i did it the first time(this time with some thread lock on the tiny screw)and now when I turn the key in the ignition the metal goes left hits the block and goes right and gets stuck and doesnt want to idle back and forth like it used to.It makes a sound and gets sort of stuck there.But when I hit the ignition button it goes to the center and doesnt idle back and forth with the engine sound.The FI light is off and the bike runs fine but I dont know if this is good.Can anyone help me with this problem it would be greatly appreciated
RE: FI Light fix needs to be fixed
if it goes bzzzt click and dont move then its fine.
if it goes bzzt click click click bzt, its fine.
as long as the fix is installed and the fi light is off, its fine
if it catches on fire, your fuc*ed
