FI light FIX
hey guys, i ust recently bought a yoshi pipe for my 06 zx6r, i bought it used and it came with two metal pieces which are for the servo. anyone have pictures of it installed, cuz I've tried several ways of installing it and the light is still on ...thanks.
all the servo stops should look like the muzzy one. unless its the type that you put on the ends of the cables that come off the pipe end. can you post a pic of your pieces ?
if you pulled off the stock hex piece and put the forked looking one on and then the muzzy looking one. what shape would it make ? it should only be one piece that bolts on the servo motor though. kinda hard not looking at anything. you can pull off the hex just dont let it spin while your taking the bolt off or turn the key with nothing on there, unless its allready spinning around, then youll have to reset it anyway.
There should be a couple of spots on the bracket that will hit a couple of the stops by the servo. just make sure they hit the stops and the servo doesn't just spin around that's why you have the FI ligh on still.
anyone have the servo stopper on their bike for a yoshimura. The L shape bracket seems like it bolts on where the they hex screws are and the muzzy looking piece seems it bolts right on top of the old hex piece ... i think its suppose to hit the forks coming off the L bracket piece but the light is still on after i turn the key.
