digital gauges
Old Oct 5, 2006 | 01:04 AM
Olympia636's Avatar
Default RE: digital gauges
Thats a analog tach right? If so, why would you want to put a digital tach on there? Analog tach's kick butt!!!
Old Oct 5, 2006 | 01:52 AM
eclipsehunter2001's Avatar
i like the way it looks and it will free up space i want to add a gear indicator and i could custom make the bracket make it look more clean and updated
Old Oct 6, 2006 | 06:18 AM
speedracer138's Avatar
I looked at the wire diagrams and it may work. Only problem I see is that the voltage to the 02 guages are higher for the instrument backlights (12 volt) The LED on the 03-06's are like 3-5 volts. You can only try and see if it will work. The same wire colors go to the same sensors on both bikes. You will probably have to relocate / repin some wires. Even the connector looks the same.
Old Oct 6, 2006 | 06:53 AM
great , what i can do is add some resistors to drop the voltage and we will be set... hey speedracer where can i get a copy of the schematic you have... ?... and thanks for checking that out for me i really appreciate it
Old Oct 6, 2006 | 05:45 PM
Eklipse636's Avatar
IMHO i HATED that guage cluster, looked cool, but was not economical. i like my zx14's analog tach much better than that **** you cant read.
Old Oct 7, 2006 | 01:17 AM
Joe00zx's Avatar
I think this would be a great idea. If you get this to work you should make a write up on how to do it. I think I got used to the SV650 digital speedometer too much.
Old Oct 7, 2006 | 06:38 AM
I have to tear into my guages again because one of my blue LED backlights has a bad connection. Has anyone tried an 05-06 guage in an 03-04? The 05-06's have the temp and trip meters swapped and also have a "fuel" message when the reserve light is on. The low fuel light is so hard to see/ notice. I have to duck down to see it.
haines123
Sep 18, 2006 06:55 AM
GRNLNTR
Sep 8, 2006 06:16 AM
Feral_Osprey
Ninja 250R
May 24, 2006 12:25 AM
pimpswithmints
Apr 12, 2006 12:42 AM
technophile
Ninja 500R
Dec 16, 2005 09:58 PM
