digital gauges
Old Oct 4, 2006 | 05:27 AM
eclipsehunter2001's Avatar
Default digital gauges
does anyone know how difficult it would be to get the 636 gauge to work on my 2002 zx6r
Old Oct 4, 2006 | 06:01 AM
speedracer138's Avatar
Default RE: digital gauges
You would have to figure out which signal wires go to which instrument/ sensor for both bikes. It may work.
Old Oct 4, 2006 | 06:06 AM
i want to try it , i mean i can make a plate to mount everything onto and make it look nice i just do not know what the lay out of the pins are , and if the plugs even match
Old Oct 4, 2006 | 06:16 AM
You'll have to either buy a 03 guage or compare with one, maybe a friends bike, to see if the connectors are similsr and the number of wires are the same. Is you guage fully electronic or is there a cable for the speedo?
Old Oct 4, 2006 | 06:20 AM
i do not see a cable for the speedo, just a plug that goes to the back of the set...i am going to look for a schematic in my manuel right now though
Old Oct 4, 2006 | 06:31 AM
If you can figure out the wiring/ sensor relation, it could be made to work.
Old Oct 4, 2006 | 06:33 AM
well i found my wiring diagram, does your 636 have the digi speedo? if it does can you check to see if you can find your wiring diagram
Old Oct 4, 2006 | 06:36 AM
I'll compare the two against each other and let you know.
Old Oct 4, 2006 | 06:51 AM
ok great if you want i can tell you the layout i have for my bike from the manual.. yeah i think this would be a great mod if it can be done
Old Oct 4, 2006 | 06:54 AM
I have a manual for your bike already. I will print the wiring diagrams and look at them. I'll let you know tomorrow. It's Sleeptime.
