Brake light Hard on...
Old Sep 17, 2008 | 02:49 AM
Qomomoko's Avatar
Question Brake light Hard on...
I have a 05 636. Put on Dual two bros exhaust and its fender eliminator. I also have a scorpion alarm system and it connects to the turn signals. When my alarm was acting up because I had swapped two wires on the turn signal, then fixed it and alarm good, but as stated, my brake light is hard on. For some reason after installing it, by brake light is hard on. Only in parking is the tail light on and brake off. Fuses good, disconnected the turnsignals and license plate light from connectors( in case had wiring mixed up or a ground), then saw no fix so took fuses out for turn signals and head light and still. Brake light is hard on. Tail light should be on when bike on and brake on only when braking with pedal or hand, correct?,Suggestions?
Old Sep 17, 2008 | 03:34 AM
Qomomoko's Avatar
Figured out the problem.. well my dad did. the pedal sensor was too tight so it was as though always braking..... loosened it up and now not hard on. On when brake with hand or pedal..
Old Sep 17, 2008 | 03:48 AM
wildacex187's Avatar
nice good job. buy your dad a beerr
Tdizzle
Apr 18, 2009 06:29 PM
ntloser
Oct 23, 2006 02:07 PM
02kawipawi6
May 7, 2006 07:05 AM
funtoos
Mar 28, 2006 09:04 PM
BigRig18Wheeler
Mar 6, 2006 08:39 AM
