Any 03-04 636 Owners?
Old Feb 8, 2010 | 08:58 PM
2k1w=no$'s Avatar
Default Any 03-04 636 Owners?
I had this posted in the general tech section, but no 03-04 owners must go in there, so I thought I might get some help in here.
I was wondering if an 03-04 636 owner would be able to measure there swingarm for me. I need measurments from the swingarm pivot to center of axle slots, how wide the swingarm pivot(inside) is. and how far it is from the axle slot to the block in front of the wheel. Thanks.
Old Feb 9, 2010 | 03:50 AM
CDN ZX6r's Avatar
I have an '05 ZX 636. I think 768 RYDA has a 2004 model. Send a pm and he might be able to help you out. Good luck. What do you need the swing-arm measurement for anyways?
Old Feb 9, 2010 | 04:08 AM
christadore2's Avatar
I have a 03 zx6r, 636 (wife's bike). I will measure and post what i get for you.
Old Feb 9, 2010 | 04:20 PM
As promised here is what I got for measurements : Swing arm pivot to center of slots : 21 3/4 " Axle slot to brace (tire side) : 14 5/8 " and last but not least swing arm pivot: 10 1/4 " The swing arm pivot was tough to measure because there is flanges on the frame and bushings on the swingarm, chain guide, chain, ect...plus just trying to get in there to get a accurate measurement. The measurement is from frame flange to frame flange. This included the bushings on the swing arm which is total width inside of frame. Hope this helps, anything else just ask, ill do my best to help.
Old Feb 9, 2010 | 09:57 PM
2k1w=no$'s Avatar
Thanks chrisadore2.
Old Feb 10, 2010 | 02:16 AM
going supermoto KLX?
Old Feb 10, 2010 | 02:05 PM
2k1w=no$'s Avatar
A supermoto klx is nothing in comparision to this project in the works. More to follow in time.
On a side note the 636 swinger is not a good starting point even for modifications. The search is still on.
Old Feb 10, 2010 | 03:59 PM
seeing your klx makes me want more info on this . good luck on ur search
sampson
Ninja 250R
Jul 16, 2008 10:39 PM
HawaiiRider
Jun 19, 2008 01:51 AM
slip
Nov 8, 2006 01:55 AM
LeftyS7
Jul 27, 2006 05:34 AM
ZR810
May 18, 2005 03:41 AM
