alarm installing i am stuck!!!!!!!
ok guys so here is the deal i am installing a alarm on my bike currentyl i have got the whole alarm done besides getting the horn to workthe instructions says that it is a (-)200mA horn output andshoud be connected to the low current ground output from the motorcycles horn switch. now my brothers friends who is a installer at car toys said that i need a relay to bump the power up. i am confused on how to this is there anyone who can give me a illustration of this i am confused thanks
alarm brand is autopage the m-200 only one they make has built inshocl sensor and ignition switch along with using the factory horn as the siren. this is were i am stuck
You'll need a Bosch relay and wire it directly from the battery. The positive wire should hook up to terminal 30, wires from your horn to 85 & 86, run one wire from 87 to the horn and another wire from the other horn terminal to ground. Ask your buddy to help you but you should follow the manufacturers instructions for the warranty.
