2nd Gear
Old Jun 22, 2007 | 03:17 AM
ZXNinja8's Avatar
Default 2nd Gear
I have a 1992 ZX6 type D Ninja and when I get onthe throttle, about hitting 7000-8000 rpms, it slips out of 2nd gear into neutral. Anyone have this happen before? I was figuring it has something to do with the 'dogs.' I'm not exactly sure. Any thoughts?
Old Jun 22, 2007 | 04:03 AM
Default RE: 2nd Gear
Does sound like a tranny inspection is in order.
Old Jun 22, 2007 | 02:56 PM
picking on the dogs again huh.j/k i had a 91 ninja 600 and it used to do that. i just put up with it cuz i did not want to spend any money on it. then later on the motor blew up and i did not have to worry any more..lol sorry im not much help but it does seem to be comon in the early 90's ninja 600.
Old Jun 23, 2007 | 02:35 AM
shinobi636's Avatar
Yep, sounds like the gear is worn, or moved on the cassette.
Old Jun 23, 2007 | 02:48 AM
speedracer138's Avatar
Just try adjusting your shift lever down a bit first. Also adjust your chain & lube it. If it still happens then an ispection is n order. Could be the shift cam (Star). It is a problem with some ZX6R's. If that is the case, check with www.factorypro.com .
jstroudzx6
Apr 29, 2021 07:31 AM
red
Jul 29, 2011 10:49 PM
trey
Sep 11, 2006 05:21 AM
moparman48081
Sep 6, 2006 10:04 PM
taystyl
Jun 2, 2006 04:37 AM
