2nd Gear
I have a 1992 ZX6 type D Ninja and when I get onthe throttle, about hitting 7000-8000 rpms, it slips out of 2nd gear into neutral. Anyone have this happen before? I was figuring it has something to do with the 'dogs.' I'm not exactly sure. Any thoughts?
picking on the dogs again huh.
j/k i had a 91 ninja 600 and it used to do that. i just put up with it cuz i did not want to spend any money on it. then later on the motor blew up and i did not have to worry any more..lol sorry im not much help but it does seem to be comon in the early 90's ninja 600.
Just try adjusting your shift lever down a bit first. Also adjust your chain & lube it. If it still happens then an ispection is n order. Could be the shift cam (Star). It is a problem with some ZX6R's. If that is the case, check with www.factorypro.com .
