06 636 immobilizer/starter lockout switch
Ok, so I'm curious what these two wires are in the front end of my 06 636. A light-blue wire and a red/green wire going into a terminated connector. It is located inside the right fairing near the turnsignal connector coming right off of the main wiring harness. According to the wiring diagram, the R/G wire goes to a "Starter Lockout Switch" (located in the left handlebar switch housing). The light-blue wire goes into the "Immobilizer / Kawasaki Self-diagnostic System Connector". So what the hell are these two things? Thanks
-Dan
-Dan
RE: 06 636 immobilizer/starter lockout switch
Ok, I've discovered that this connector has something to do with programmable keys (ie the correct key with the correct computer chip inside). I know my car has keys like this, but I did not know the bike has a system in place as well. I assume that the European version or older models have this active. Apparently when the key is removed, the FI light blinks to indicate the system is operational. Now how would I go about making this system work on my bike?
Ok, so after working through Kawasaki's Customer Service Department, I discovered that European model of the 636 has a starter lockout and immobilizer built in. Seeing as the wiring these devices exists on the US model and that kawasaki does not have a separate production line for US and Euro models, I'm willing to bet there is a way to enable these security features on the US model.
I'm willing to bet that if I cross these two wires, it will enable the lockout and immobilizer... either that or it will short out my ECU, lol. I'm going to take a closer look at the wiring diagram when I get home from work to determine how bad this could be for the ECU. Anyone else have any thoughts on this?
ORIGINAL: dcorlando
Yeah, I decided the other day that I am just not goes to mess these wires until I know exactly what I am doing with them. Don't want to lock myself out of my own bike, lol.
