03 zx6rr suspension
Old Mar 18, 2006 | 12:53 AM
mr2turbo's Avatar
Default 03 zx6rr suspension
i've been looking around and can't find anything about how adjusting your swingarm pivot point affects handling, anybody have links to good articles or can give a good explaination?
also, is there any good places or recomendations on brands etc on buying shims to raise the rear suspension? thanks!
Old Mar 18, 2006 | 12:56 AM
Notstock's Avatar
Default RE: 03 zx6rr suspension
http://www.gostar-racing.com/club/mo...ion_set-up.htm
start here. There are instructions in your manual for adjusting rear shock and a tool in your tool kit that came with the bike.
Old Mar 18, 2006 | 12:59 AM
murphmaster5's Avatar
dude this sounds weird but ive been trying to find info on how to do a lot of things with my 03 rr also so if by chance you find some stuff out let me know, mine didnt come with a manual
Old Mar 18, 2006 | 01:04 AM
Notstock's Avatar
check down a few post for a member named speedracer138 I think he has one. The thread is called installing the daul head light mod.
Set the sag on your bike bro you will be happy you did.
Old Mar 18, 2006 | 02:02 AM
mr2turbo's Avatar
i have the sag set front and rear i've set my compression and rebound also, i've been doing club racing with an "old"cbr f4...so i don't know what the deal is with these new bikes and the adj swing arm pivot...and how it affects the geometry?
the rear shims are because i want to go with a 70 series front instead of the 65 for a slightly larger footprint at max lean but mostly for race tire selection and i don't want to pull the forks up to compensate, and the rear shim should do the trick while also giving me a little more ground clearance without having to shell out for the ohlins with the adj ride height
and my tool kit didn't come with a spanner wrench, did the previous owner just loose it or does kawasaki expect you just to use a punch and hammer?
Old Mar 18, 2006 | 07:41 AM
speedracer138's Avatar
Yeah, thats about right. Kawasaki expects you to use a punch & hammer of buy an expensive spanner wrench. I will also post a "DIY" on a rear suspension measuring tool/ device because I found it to difficult to do it accurately just holding the bike up, even with help from a friend. I will do a post with pics after I get back from Vancouver, B.C. next week.
cegusman
May 26, 2012 12:24 AM
Kourtneyhk
Oct 18, 2009 05:42 AM
Cold Iron
Sep 30, 2006 07:57 AM
BRIGHT
Aug 9, 2006 10:23 PM
BRIGHT
Apr 13, 2005 06:52 PM
