No Spark from plugs In My '97 Ninja zx-1100???
I have been trying to get my bike up and running for the past week or so and everytime I think I come to figure out what the problem is I run into another road bump...the newest being there is no spark coming from the spark plugs...
At first, I thought maybe the engine wasn't getting any gas; however I tested that theory and the fuel pump is sufficiently pumping...I took out one of the four plugs and it gave me no spark...I replaced it and another spark plug gave me no spark...
What could be going on???
Does anyone know if the coils/ignition box could be the root of this? Or, what is it...
Please help....aghh....[sm=headbang.gif]
Absolutely it could be the coils, I would try and check the resistance of each spark plug wire then the coil resistance and compare w/ the shop manual then check the connections on the coils and trace back to the battery and ground both for continuity and voltage. If you don't have the manual, let me know and I'll check the specs. for you. But will be away for Father's Day.
bnpain
bnpain
seizetheday4eva
Aug 14, 2012 04:25 AM
