Givi stuff - to add or not to add
Old Jul 17, 2009 | 08:24 AM
Exactly how do I adjust the rear shock? I haven't even looked into that yet.
Just as you would with any other ride. Now that you will have added weight, pack your bags, do your measurements with all of your gear for rider sag, and you may end up going up a size in springs now.
Old Jul 17, 2009 | 01:34 PM
yorgomiami's Avatar
First day riding with my new luggage - for commuting I'm only taking my side cases. The top case adds too much bulk. The side cases alone give me enough space for all my ****. I'll use the top for 2up and/or touring.
With the side cases on I can't tell any difference while on the move. I know they are there only from the rear view mirrors. Otherwise the bike does not feel any different, even at 80mph.
Old Jul 17, 2009 | 01:37 PM
yorgomiami's Avatar
I'm sure it's a collar ring just like all other bikes. I just can't figure out where you access it.
Old Jul 18, 2009 | 01:56 AM
I have not adjusted the 11, but I cheated on my 10r. put on the penske shock, uses a pin for easy ride height. The other bikes, I still use the spanner wrench. But found it easier to support the ride on your jack stands with drill rod going thru the swingarm pivot for support. Releases the spring tension.
tkm433
Sep 16, 2014 02:08 AM
seth6025
Feb 18, 2011 12:14 AM
motoguy128
May 9, 2007 06:28 AM
gotrice
17
Jul 31, 2006 05:01 PM
MAD KAW
Apr 4, 2006 07:20 AM
