Water pump cover,
Hi all,
Anyone have a good schematic or directions to removing water pump cover on a 2002 ninja 500?
I was going to change the gasket as it was leaking.
Do I need to remove the 2 or 3 twelve millimeter bolts underneath?
The solid metal tube attached to the block and pump cover, is it just held on by an o-ring gasket or what?
Any detail would be appreciated, Thanks!
Thank you for the schematic. I guess my big question now is the metal tube that is connected to the pump cover and inserts into the block, how does that release? Is it sealed by an o-ring and it just needs a good tug or what? The cover is loose and is separated from the back plate, but the tube seems to be holding it back.
klxstiffler
Mar 21, 2007 03:30 AM
