water pump leak
Old Feb 1, 2006 | 04:17 AM
fullhouse's Avatar
Default water pump leak
need advice. I have a 1996 1500 Vulcan Classic. I bought it November '05 with just over 7500 miles on it.
It had a bad coolant leak from the weephole, I have replaced the water pump seal & cover gasket, and now it has a cold start coolant leak, it leaks out at the weephole (about a 1/4 cup) until it gets up to operating temp, then it stops. I have put about 50 miles on it since the seal replacement. no coolant in the oil. could the water pump cover be causing this problem?
Coots Magee
Ninja 500R
Jul 22, 2012 03:35 PM
klxstiffler
Mar 21, 2007 03:30 AM
nucci13
Aug 2, 2006 06:34 AM
Marty
Dec 22, 2005 03:23 AM
